Question on programming TX
Im interested in building the f-14 plans from parkjets.com, the model with the variable sweeping wings. Would there be some way to set up mixing that i could have ailerons when the wings are out and when i sweep the wings back the ailerons shut off and the tailerons kick in to fly it as a delta wing. I assume if its even possible its above the programablity of my dx6i, but if it were possible what would it take.
i just think it would be so cool to be able to fly like that.
Im also interested in putting together the su-37 also from parkjets. it has a thrust vectoring option, if any one is firmilar with it. As I stated I have a dx6i, he says it requires 7 channels to set it up how he has it. Could i set it up with 6 channels by just removing his "yaw thrust vectoring" which is accomplished by having both pusher probs on seperate channels so to yaw thrust vector it slows down changes the power to each motor to create the yaw. Im mainly interested in the roll and pitch vectoring. Would i be able to accomplish this on the dx6i.
