Help - Interference with Hitec Electron 6
Before you accuse his transmitter, check to see if others on nearby frequencies cause the same results.
When you say his ch42 Tx causes interference to your ch46 Rx, was your Tx turned on, or off? If your Tx was off, many Rx's (I'm unfamiliar with the Electron) will act like they're having a seizure from any nearby RF source. My Hitec (RD3500?) goes nuts near flourescent lights, but only with certain servos. Turn off the light, or remove that servo and everything is fine...
