RCU Forums - View Single Post - JR DSX7
Thread: JR DSX7
Old 12-17-2009 | 09:35 AM
bruce88123
Default RE: JR DSX7
ORIGINAL: Korps
Thanx guys. The reason for asking about, ''Is it worth it'', is because I've read about people having trouble with 2.4 a lot. Loosing signal to the plane etc etc. Don't know if this is a common thing. On the point of keeping the same manufacturers gear together with 2.4 - it would then be better for me to go JR or, as opjose pointed out, Spektrum - since these two I can get locally. Futaba and Airtronics I have to drive quite a distance to get at this stage.
This would certainly be a point to consider in your case. For others it may not be such a factor. Your LHS might also be able/willing to order the others for you but this could be bad if the need occurred for a spontaneous purchase.
Keep all options open and make the choice best for YOU.
