wouldn't call it anything yet. We are working towards a version of the engine that has reduced exhaust timing than the current version. In theory, it will allow it to turn slightly larger prop more comfortably. It should produce a little more torque at lower rpm. Total output will not change since nothing is being done with displacement. We are simply trying to slightly modify the torque curve without doing any engine overhauls. The mod is very simple and requires nothing new
I should be receiving my engine with this change in a few days. We'll be doing everything the weather permits us to do to get some test results before Jan 4.
