RCU Forums - View Single Post - FUNJET
Thread: FUNJET
Old 12-19-2009 | 02:57 PM
  #851
chippedprop
Default RE: FUNJET
ORIGINAL: rino
Hi guys,
I'm ready to try out a very light setup. I love my Mega 16/25/2 on 5S but I want to change it up a bit.
What's the latest on the best lightweight setup. The Microdan was the rage for a while. Is is that or the Scorpion now?
Also, will an eflight 30 amp esc work for a lighter setup? My CC 80 will come out too.
Steve
I would go with the MicroDAN 2900kv on 3 or 4 cells use a e flite 60 amp ESC as it's a proven ESC to run the motor...any other ESC as for now it may stall...Dan and I are working/testing on the issue
On 4 cells expect 110 mph plus and unlimited climbs Use APC 4.75 x 4.75 carbon fiber prop
On 4 cells you will pull 50-54 amps if I remember the numbers.
Your looking at a motor weight of 1.5 oz making 600 to 700 watts
Set ESC to switching rate of 16hz...timing to 5 deg. to start you can play with the timing to increase power
use a turnigy 2650 4 cell get 2-3....flight times about 5-6 minutes...4 minutes WOT
