ORIGINAL: huison2005
Full thorttle WOT about 2600watts , 65amp with Xoar 18x10wood-E prop
Fot the vertical up line max amp draw is 45amp and used 1700Watts
Fly p-09 for 9min and land 2200 to 2400mah used (i use 4900 mah Rhino5sx2packs)
So ther are still planty of reserved power for it . . . .
tIANci (and anyone else running 10S):
Are you also using ~2500mah for a flight?
If this is the case, 4000mah 10S Zippy will be ideal - same weight as 4900 8S Rhino and motor still 2oz lighter than Hacker
Think I made my final decision
