RCU Forums - View Single Post - Sebart Wind 110
Old 12-19-2009 | 08:49 PM
  #495
huison2005
Default RE: Sebart Wind 110
ORIGINAL: gaRCfield
ORIGINAL: huison2005
Full thorttle WOT about 2600watts , 65amp with Xoar 18x10wood-E prop
Fot the vertical up line max amp draw is 45amp and used 1700Watts
Fly p-09 for 9min and land 2200 to 2400mah used (i use 4900 mah Rhino5sx2packs)
So ther are still planty of reserved power for it . . . .
tIANci (and anyone else running 10S):
Are you also using ~2500mah for a flight?
If this is the case, 4000mah 10S Zippy will be ideal - same weight as 4900 8S Rhino and motor still 2oz lighter than Hacker
Think I made my final decision
gaRCfield , you won't be regrat if you go 10s i tell you .... you will need all the power to fly p schedue . Recently juist came back from
Thai ""KING-CUP" , they are using all full 2m pattern plane .... i am flying the 110size as you can see the 2m flying box is large ,
when the wind pick up .. . .that is the time you need the extra power at the top menuever ()and with the extra weight you carry , the plane is stable and track well !
track well too ,,, but you need a break setting to slow down the down line abit .
