ORIGINAL: melonpeel
I'll add a few..
Never use threadlock on plastic.
If you strip a screw, you can file or dremel a notch in the head for a flathead screwdriver.
yeah, about thread lock on plastic, it turns into super glue, so be careful around bearings and turnbuckles, turnbuckles will freeze up with lock-tite.
as for stripped screws, the best dang tool i bought in a long time was a Grabbit Pro from ACE hardwear, it drills then pulls screws out with a drill, worked wonders with my engine mount bolts! not bad for $15
