RE: Hits and Misses of H-9 Corsair
I will be glassing the whole wing as I will be sanding a ton of wood off it to give it a better shape allowing the curves to flow better. The fuse I will probably only glass back to the wing saddle as it has alot of hangar rash form setting up in the stand. The aft of the fuse from the trailing edge of the wing back is very strong so depending on weight need to balance I may go ahead and glass all the way back. I may also go with the RCGF28ccV2 depending on weight. It is almost the exact same dimensions and weight as the 20cc. That way I can swing a bigger more scale looking prop.
Shane
