O.K.......
I FINALLY got around to solving a Problem thats been Nagging at me (and my RXB-1 ) for a while now.
You all were probably wondering why I never finished the RXB Break In Video?...Or mebbe Not?
Well I couldnt get the engine to Prime.....
Long Story Short,,,,,it turned out to be a bad GasTank.
You can blow air into the tank, and air (or fuel) will come out the other end. Which is what you would Expect from a good tank,,,,right?
But if you connect it to the engine and try to Prime it,,,,,,No Go! Wont work[:@]
Weirdest thing I've ever seen on a Nitro. The tank must be Partially clogged or something......
I finally swapped out a different tank and the system Primes up perfectly.....
Guess I will be buying a new Tank from HimotoRacingUsa......Glad the Problem is Solved, cuz that RXB needs to hit the TRACK!
