RCU Forums - View Single Post - Someone please have a problem or something!!!!
Old 12-20-2009 | 07:57 PM
  #50
bkfamily1
Default RE: Someone please have a problem or something!!!!
Remove the little hose barb that screws into the tank for the fuel pickup and check the hole in the tank that it threads into. I had an issue with the RXT wanting to run lean and inconsistently. I finally found that the hole in the fuel tank was not all the way through restricting the fuel flow. It seems unlikely, but it could be the same issue you are having.
BK
