RE: 2.4 ?
Yup Rich you should be good to go if you are using an appopriate charger to charge that battery with.
Lots of folks will try to use the typical 70Mah wall chargers they are use to by charging for an extended period but there is no good way to know if your battery is up to capacity after charging that way and as a result I see more and more problems showing up simply because their batterys are not fully charged. Its easy to get confused with extended charge periods especially if you fly frequently.
