RCU Forums - View Single Post - Want to move elevator servo to tail - tips?
Old 12-21-2009 | 05:50 PM
hrrcflyer
Default RE: Want to move elevator servo to tail - tips?
Joe,
I'm sure you've already thought about this, but make sure you have enough channels in your receiver. I know you can use a reversing Y harness, but I've found them not as dependable or consistent as I like. The two servo's never seem to travel the same amount, even when I used the type adjustable type of reversing Y harness.[:'(] I've also found the reversing Y harnesses will change the servo travel depending on weather.[:'(]
David
