3W 75, 85 B2, or BME 102/105 for the H9 Sukhoi??
If you are thinking about twins, then you should also consider the DA-100 or 3W-106, which cost the same as the BME and will have more power. The downside is that they weigh more.
If you are thinking about singles, then you should consider the ZDZ-80, which costs about the same as the 3W-75 but has more power and weighs less.
Any of these motors will fly the plane well, but some will be more ballistic than others.
