RCU Forums - View Single Post - Mixed Tamiya Electronics issue... maybe?
Old 12-22-2009 | 12:41 PM
CountChocula's Avatar
CountChocula
Default Mixed Tamiya Electronics issue... maybe?
Hello All,
I have a question regarding movement behavior of a tank of mine using a Tamiya Sherman DMD and a Pershing MFU. I put these electronics is a stock WSN T-34 (meaning stock gearbox at least). If I push the throttle forward and move the tank, I can turn the tank by pushing the stick left or right as you would expect. However, if the tank is at a standstill, if you push the stick left for instance, then while the stick is in the full left position, start pushing it foward (to make a left from a stand still), the tank will actually kick right! If I repeat the same steps and try to make a right hand turn from a stand still, it will kick left. If I have any foward movement (at any speed), it will turn left and right correctly while on the move. Is this normal or possibly an issue with using mixed electronics?
Thanks alot all...
Dave
