ORIGINAL: evdreamer
I think that transmitter only has servo reverse switches on it? However, it doesn't have a feature that you need to make the swash move up like it should. You need a programable transmitter that has a swash menu for Pitch. That way you can change the direction the swash moves, so it will go up.
There is one thing you can do. It is called a grip flip. You basically make the grips so they are leading edge controlled. You have to flip the grips 180 degrees and flip all the head components. That will fix your problem. The swash will still move the same, but now you will get positive pitch when you give more throttle. It is kind of hard to explain it.
Nick
Hey Nick!
I read the post differently, not that the swash was going in the wrong direction, rather that all three servos weren't working together hence the 120' setting suggestion...
Which is it OP?
