RE: Mixed Tamiya Electronics issue... maybe?
Check your plugs on your cable that runs from the dmd to the mf unit. I had one do similar stunts and discovered a wire had backed out of the molex plug body on this cable. If one has backed out, you'll see it. I used an icepick to push it back in, and everything worked.
