RE: Struggling with single rotor basics V2
I nearly have the Beam E4 back together. I replaced the tail shaft, tail pitch lever and vertical stab on the tail... the main shaft, feathering shaft, main drive pulley and one way sleeve. I still need to go through the servos. The one that caused the crash needs to be replaced and another has a stripped gear. I thought HS65MGs were supposed to be tough..... meh... The stock SWE main blades survived but the tail blades did not. I have factory tail blades but also ordered a set of KBDD neon green 61mm blades and matching KBDD paddles. It will be nice to fly this thing again.
