RCU Forums - View Single Post - Low wing trainer 60
Old 12-23-2009 | 02:23 PM
opjose's Avatar
opjose
Default RE: Low wing trainer 60
What will be nice is that you can prop it down to fly the plane in a more relaxed manner, then prop it up later to make it more speedy.
It sounds like you'll have fun with it.
The electronics will also transfer to a whole range of different planes.
If you go with retracts, make sure you use the spring music wire type gear.
The loop spring absorbs the impacts that would pull out a normal retract.
