RCU Forums - View Single Post - Proud Bird Construction Thread
Old 12-24-2009 | 04:27 PM
  #125
sahartman21
Default RE: Proud Bird Construction Thread
After the Spackle is dry sand the surface with 150 grit sandpaper on a sanding block.
The purpose is to leave a smooth surface ready for the primer.
Use a small screwdriver to clear out the hinge line.
Put some tape over the wing landing gear blocks to keep the paint out of the threads.
ID:	1341199   Click image for larger version
ID:	1341200   Click image for larger version
ID:	1341201   Click image for larger version
ID:	1341202   Click image for larger version
