RE: Sebart Wind 110
Joe,
Just one other consideration for you to think about. I know that you have ordered a new set of carbon (or fiber) gear for your Wind from your previous posts. I have the stock gear on mine and I am running an 18x0 prop. I don't believe that I could run a 19" prop and have enough ground clearence on a grass field. I am apparently nicking the grass now at times as I have some green grass stains on the tips of the prop after I land. Hopefully your new gear will give you a little more ground clearence. I seem to remember Tommy S posting that he had also ordered and installed carbon gear for ground clearence issues. Just a thought when picking out your motor and prop size.
Larry..
