RE: Balsa Drill Bits
Brass tube is best, but finding center is a PITA, I harden the area with thin CA and use frostner bits, Porter cable makes them and the home depot sells a set for like 20 bucks. Get a set, you'll use them for almost every hole drilled in wood. Start easy, bore smooth and leave almost not splintering on the back side of the wood.
