RCU Forums - View Single Post - Tomahawk-Design Bae Hawk 1: 3.5
Old 12-26-2009 | 03:07 AM
tobba
Default RE: Tomahawk-Design Bae Hawk 1: 3.5
People
Looking for thoughts. I have a Tomahawk Hawk on order, due March. Keen for thoughts on the rudder setup.
From everything I am hearing the Tomahawk is pretty much identical to the SG. I saw a near disaster here in New Zealand with a SG Hawk on its second flight a month or so ago. This model was built by a chap that has been flying and building for many years, including many Jets. I did not view the rudder setup first hand, but I would expect it to be correctly setup. I am aware of a similar issue on the prototype SG Hawk but have heard nothing since. Maybe future kits were upgraded?
This is a big surface. Does it need 2 servos? Does it need a double arm - rigid push pull? or maybe more strengthening around the rudder tube where it mounts to the fuse? I am far from questioning the caliber of the design of either the SG or Tomahawk models - they are the best of the best, hence me buying one...! However the result on this model was a little disheartening.
See a few shots attached of the damage to the SG Hawk. One prior to the incident. These guys were very lucky. Just managed to squeeze it back on the runway.
Thoughts would be appreciated.
ID:	1341883   Click image for larger version
ID:	1341884   Click image for larger version
