RCU Forums - View Single Post - Classic Fundamentals...a tutorial...post your building techniques HERE!
Old 12-26-2009 | 04:53 PM
  #97
BERUSTY
Default RE: Classic Fundamentals...a tutorial...post your building techniques HERE!
Classic Fundamentals...the Dirty Birdy is painted!
This is a continuation from post #41 discussing finishing resin and the BVM pre-primer pin hole filler.
The Dirty Birdy is one step closer to flying today. I picked up the fuselage from my new Naperville painter, Tim Olson. I met Tim at my Fox Valley R/C Fall Pattern Classic in September. He is a professional automobile restorer, specializing in Camaro and Trans Am vehicles from the early to late 70's-...a classic car restorer! Anyway, he is returning to pattern after some years away (we always get'em back) and I asked if he had ever considered doing some paint work...
The Dirty Birdy uses the PPG base coat clear coat system (the numbers will be posted later). I am very pleased with the results and look forward to dropping off a few other projects...Deception and Super Lucky Fly Supreme. The color scheme is a copy of the RCM, Ben Strasser construction article model.
The rudder, which had one application of the BVM pin hole filler, one coat of rattle can gray primer and a coat of sealer- turned out very good and will definitely use this fine product again.
Rusty Dose
Team Futaba
ID:	1342239   Click image for larger version
ID:	1342240   Click image for larger version
ID:	1342241   Click image for larger version
