RE: Putting engine upright on Ultra Stick?
The only problem comes if it make the carb sit too high in relation to the fuel tank. Normally the carb should be about the same height as the center of the fuel tank. If you run muffler pressure and make sure you don't tune super lean you'll be OK.
