A small problem concerning backplate help needed.
So long as there are no leaks then you should be fine with just 3 screws. Be aware though that any screw hole that goes into the crankcase MUST be sealed.
I have my doubts that the backplate adds much integrity to the crankcase when you consider the engines that use a plastic backplate (I think even Irvine uses them).
