RCU Forums - View Single Post - Sig Rascal 40 - Flaps?
Old 07-30-2003 | 02:33 AM
Monarch97
Default Rascal Flaps
Congratulations Ross on your door prize windfall.
My first Rascal had a TT46Pro motor and was a real screamer. More than enough power, and very economical in all respects.
When I was assembling that model, I had the opportunity to test fit a .60 2S and found it too large to install without unaceptable alterations to the fusalage. In any event, the TT46 was more than adequate for power and speed.
At the time I owned that plane, I did not have the option of flaperons, and found it hard to slow the speed down enough for short landings. The Rascal has a long glide ratio even at engine idle, and wants to keep on flying and flying and flying.
After the untimely demise of that model, I have replaced it with an identical example, but this time substituted a Saito .56 motor, and a transmitter with flaperon and airbrake functions. With the addition of a Bolle 3 blade 11.25 X 6.5 prop, the Rascal can park itself on a postage stamp. (A real big postage stamp with grass growing on it.)
The installation of a Nelson intelligent glo driver has made starting the engine very easy, and allows for a slow and stable idle. The Rascal can accomodate a substantial payload without detrimental effect on performance, and the extra weight of an onboard glo driver seems justifiable considering the advantages of this device. (IMO)
I hope you enjoy yours as much as I am enjoying mine.
Mike
