RE: MK Aurora 60 build - engine installation question
IM made the mounting plates with tapped holes for OS and YS engines. The plates were screwed to the engine mounting plate with large wood screws. The MK soft mount works nicely or you can make your own plates. I've used aluminum successfully, but you must be careful not to over tighten the bolts in the aluminum threads!!
Good luck!
Will
