RE: Skymaster L39 build
Hi Guys
The layout wasn't too much of a problem. Having the full depth cockpits means its not possible to use the front tray but if you mount the bits on the floor its fine, I used the front for the ECU, pump and air-tanks think there's a picture of my layout further back in the thread. With the aft tray you have to be careful with the height of the equipment. Plenty of space on the sides and a little at the front of the tray where I mounter the 5U pro valve. It did take me a while to get the things positioned correctly.
The Plastic I used was 3mm in thickness, it depends on how far you want to pull it but I found anything between 2-3mm works well. Sorry for the metric measurements.
Cheers, Alex
