RE: Wing Loading....
Biplanes can be less efficient than monoplanes due to the interference of the air flow caused by two nearby wings. If the wings are spaced at least a chord length apart, it is quite close to the same efficiency as a monoplane but, if they are closer together, the efficiencies can fall as low as 70%.
