RCU Forums - View Single Post - Some battery & charging questions...
Old 12-28-2009 | 04:06 PM
ThEoNeS911's Avatar
ThEoNeS911
Default RE: Some battery & charging questions...
Get yourself a peak-detection charger. It will generally save you the problems of:
long charge times
unable to detect when battery is done/in progress of charging.
overcharge
undercharge.
Get one and charge your battery at 3-4 amps (3.3 is the sweet spot). This will let it charge faster, and they usually tell you if there was an error, if its in progress of charging, and when its done. (by screen or a single LED). Some more advanced chargers can charge LiPo, tell you how much voltage and mAh is in the battery, and so on.
Heres a good, cheap, efficent charger that gets the job done.:
www3.towerhobbies.com/cgi-bin/wti0001p
If you're looking for more peformance, get one of these:
hobbyking.com/hobbycity/store/uh_viewItem.asp
