RCU Forums - View Single Post - Official HPI MT2 Thread
Old 12-28-2009 | 04:25 PM
  #20216
SyCo_VeNoM's Avatar
SyCo_VeNoM
Default RE: Official HPI MT2 Thread
Only advice on GPM parts I have is stay away from the aluminum arms (unless you want to make a shelf queen)
I got a set and took them off. After a jump they cracked the hub that attaches the arms to the chassis, and royally bent the pins that hold them on. Honestly it wasn't even that high of a jump(under 2 feet) to cause the amount of damage that was done. I had to cut them off the pins were so bent... Went back to the nylon ones and have had no issues since.
Aluminum parts I use: steering saver set, front knuckles, rear wheel hubs, Front shock tower, and rear shock tower.
I actually recommend the front knuckles seeing on the 2 trucks I own had issues with the knuckles stripping and falling off. Put the aluminum ones on and never had an issue since.
