RE: How to do EI
if you have room to do it, make a timing ring to go over the prop adapter to hold the magnet and clamp the sensor to the crankcase snout with a hose clamp, that's about the simplest, other option is to take a hole saw to the stock flywheel and put the magnet in that then move the sensor to where it needs to be
