RCU Forums - View Single Post - How far is far enough
Old 12-29-2009 | 04:59 PM
  #36
merugo
Default RE: How far is far enough
uhhhhm....100' minimum distance at ground level from a High Voltage triphase transmission line at 380KV 1500A means that flying at ground level with 50' metal line, you are fishing into an mean electric field of 500V/m. In other words you are fishing with metal wires into an electric field at a potential of 7.5 KV more than the potential of pilot. And things should be worse if you fly above ground level....
