RCU Forums - View Single Post - ZDZ 40 RE F3A Soft Mount
Old 12-29-2009 | 06:17 PM
  #64
cmoulder
Default RE: ZDZ 40 RE F3A Soft Mount
Thanks much! More work than I thought, but I had to figure out some of the tool workarounds as I went.
I cut the balsa ring down the middle by using double-sided scotch tape and some balsa sheet to secure my razor saw to a block of balsa, with the saw blade exposed to the side. Got a dead straight cut, and after hardening with thin CA and sanding a couple of times, the faces are perfectly flat and slide silky smooth past each other.
Ah, okay the last pieces of the puzzle. All I need now is some 1/64 ply. I have the bike tube.
Thanks again. Would not have been possible without your explanations.[sm=thumbup.gif][sm=thumbup.gif]
