ORIGINAL: tIANci
electricdarr ... you gonna enjoy her ... as for your pull-pull rudder, its easier to install it from INSIDE to OUTSIDE, means get it connected on the servo end first because the compartment is kinda tight.
A little tip I use for pull-pull wires . .
1. Fit the clevises and attach them to the rudder.
2. Feed the wires JUST insided the fuse (from the outside)
3. I have a length of carbon tube I feed down the inside of the fuse and OVER the ends of the wire.
4. Then just push the wires all the way in and down the carbon tube. Once the entire length is pushed in, simply withdraw the carbon tube, and the entire length of pull-pull wire is laying neatly all the way up into your hatch/canopy area . . SOOOO easy
Cheers, JB
