RCU Forums - View Single Post - Official F27 Stryker Part 8: Beginners to Custom Darkness
Old 12-29-2009 | 07:16 PM
  #917
Gryphon
Default RE: Official F27 Stryker Part 8: Beginners to Custom Darkness
thetrums,
I remember you very well old friend....you are one of my favorite folks on the internet.....I loved your last build...great combination.
_______________
This new proposed combination is HORRIBLE.
Great pieces individually, but horrible as combination in your application.
4S in a Stryker out of the question.
3S can be great if you can run some AMPS through it.
With 3S 5.5X4.5 you might very well be above 75A.....Forget 4S unless you are going to max out a 125A ESC or higher.
You need a CC180A to max out that motor, because 125A ESC will not do it.
on 3S with some high AMPs that motor can run GREAT, and amaze you (FAST, more power than ever before for you)....get a large 3S, or parallel (2) very capable packs as larger 3S...you will need more ESC to have big fun....But a single 3S pack can work pending your needs.
That ESC of yours on 3S will be using 5X5 up to 5.5X4.5 , try a few combinations and see.
If you don’t have that motor yet, I can point you towards a better KV.
Even for a Funjet, on 4S, I would ask for more ESC capability.
Tell me more detail of what you already have and what your goal is....Forget 4S unless you want VERY VERY VERY high AMPs....as I said motor can handle it great.
Also what you are willing to buy as needed to make it work.
Take care buddy,
Gryphon
