ok if I mail you a new fuel tank and screws. Will this fix your problem? which screw are we talking about? Can you show me a picture so I can get you the correct screws?
John
Nitro Planes
ORIGINAL: killian
ORIGINAL: opjose
ORIGINAL: killian
Order Number: 671616.
yhst-17210252890263-100882
1 NitroModels RC Airplane Sports Trainer .46- .60 - 65'' - Scale Nitro Gas Radio Remote Control Airplane
http://www.nitroplanes.com/stevtr.html
I need info on What servos to buy. I need 4. I also need to know what spinner and prop to buy for this plane.
Also I got the motor mounts but all the screws that came with it are to big. None will screw in to the the firewall. Or does the correct hardware for the firewall come with the motor? I have not bought a motor for it yet.
The last thing is the plug and hardware that came is stripped out. It will not tighten to seal the gas tank.
Thanks. You guys are great, Kevin.
P.S. What battery and charger should I buy for the reciever in the plane? I'm set on the tx.
These are basically build questions.
Please start a new thread and I'll try to help you.
Honestly all that info should have come with it. And I am missing thos screws for the motor mounts. Plus the stripped hardware for the fuel tank.
