RE: Aerofly Deluxe + dx5e + WinXP = No working
It seems like that there is some conflict with the soundcard or usb device. Try updating the driver for your soundcard and remove other usb devices e.g. joystick, gamepad, etc
You may also want to try disabling the directsound hardware acceleration.To change the audio hardware acceleration setting:
1) Click Start, and then click Run.
2) In the Open box, type dxdiag, and then click OK.
3) Click the Sound tab.
4) Under DirectX Features, move the Hardware Sound Acceleration Level slider all the way to the left (no acceleration).
5) Click Exit.
Yes, you will need the 31036 adapter to use your JR or Spektrum radio. You should keep the radio main switch off. When you insert the adapter cable, the radio should turn on automatically.
