RCU Forums - View Single Post - Finally deciding to do something special
Old 12-30-2009 | 08:41 AM
TomCrump's Avatar
TomCrump
Default RE: Finally deciding to do something special
ORIGINAL: dmheil
John,
I suggest you check out RCSB. www.rcscalebuilder.com Its a site dedicate to scale RC building. You may get some ideas there.
David
David has a very good suggestion. You'll be able to pick up a lot of info there, from how to do research, to building and flying tips.
Designers and kit manufacturers frequent the site, offering support for their products. The site members are friendly.
While most projects tend to be warbirds, there are several ongoing civilian builds.
I suggest that you take your time, before deciding on a subject to model. While there is nothhing wrong with doing something local, documentation is found easily from many sources. Pick a subject that you like. It will help to keep you going when you get bogged down.
Welcome to the world of scale modelling !!!
