RCU Forums - View Single Post - Skymaster L39 build
Old 12-31-2009 | 11:15 AM
  #105
tucson
Default RE: Skymaster L39 build
Thanks George and all,
I have always used the rubber grommets in the past. If you don't when you remove a servo and then put it back it will not line up like the last time.
The aluminum brackets they sent me were stripped out on a few of the holes. Jeff is sending me a few more. I did not use the grommets there.
I have built a lot of kits over the years, but never one like this where there are no instructions. Friends tell me this is the way it is with the Chinese jet kits. What I have found so far is to just do it your way or you will spend many hours trying to figure out how they did it. Just about have all my control surfaces finished, Starting to make some headway
Stan.
