RE: Help with Pull-Pull setup
The 7955's will buzz and is completely normal. If you want to find out if there is a load on the servo, connect an AMP meter to it and then you can be 100% sure. I will not setup a big plane anymore without using an AMP meter. It makes it very easy as well when setting up ganged servos.
