RCU Forums - View Single Post - Edge joining balsa sheets without CA
Old 12-31-2009 | 11:50 AM
foodstick's Avatar
foodstick
Default RE: Edge joining balsa sheets without CA
If you can find an old 55 gallon aquarium get the front and back long glass pieces out to lay the wood between while drying...really keeps it straight and flat.
Any glass will work, but the over thick plate is best. You really don't need to put as much weight on it unless you are laminating something with expanding glue ....
