RE: blade msr
Not sure if a battery placement will cause zero forward cyclic- the thing is very responsive when working right. I'd double check the swash movement at no throttle. That swashplate should move all around with inputs from the right stick. Make sure everything moves freely and that you don't have a dead servo/binding linkage.
