RCU Forums - View Single Post - Edge joining balsa sheets without CA
Old 12-31-2009 | 03:02 PM
twn's Avatar
twn
Default RE: Edge joining balsa sheets without CA
ORIGINAL: Tony Hallo
If you plan to wet the sheets for bending, I suggest you use Titebond II since it's water resistant. I don't know the Great Planes glue, but the original Titebond will fail if you get the wood too wet while bending.
Yup! Luckly this happend on a foam core where it was easy to fill and not so much stressed...
