RCU Forums - View Single Post - Balsa USA Eindecker 90 build.
Old 12-31-2009 | 03:33 PM
GaryHarris's Avatar
GaryHarris
Default RE: Balsa USA Eindecker 90 build.
Trudging forward with the fuselage build and a couple of issues popped up which is my fault for not follwing the instructions to the letter. When joining the two fuse halves together I noticed that the right side was allmost flat and the left side had alot of curve to it. I anticipated that and had a plan, and thank the balsa Gods it worked out.
With a little braceing, twisting and cussing I was able to get the fuse sides pretty close to eachother curvature wise and the only thing I'm worried about now is I have a slight left thrust in the firewall. I think I can take that out while sheeting the rear of the fusealge though.
ID:	1345850   Click image for larger version
ID:	1345851   Click image for larger version
ID:	1345852   Click image for larger version
ID:	1345853   Click image for larger version
ID:	1345854   Click image for larger version
ID:	1345855   Click image for larger version
ID:	1345856   Click image for larger version
