RE: CG question?
Schrockie- Use two pieces of string, one on the prop shaft and the other on the rudder hinge. Adjust the balance until the plane sits straight, then line up your ailerons perfectly straight. Unless you have some wing warp, that will give you straight and level flight both upright and inverted once you fine tune it with in flight trims.
