no glow plug starter needed??
What you need to get is a switch that you hook up to an AA battery. then you could use a spring overide and make a linkage to connect the reverse servo to the switch. Another option for power would be to use your receiver batt would be to use a resistor or a voltage regulator to keep the voltage at about 1.5 volts.
