RCU Forums - View Single Post - Wild Hawk motor problem
Old 01-01-2010 | 03:49 PM
opjose's Avatar
opjose
Default RE: Wild Hawk motor problem
Nothing should need to be changed.
Is it that with everything the way it was, when you move the throttle down ( towards you ) the motor spins UP ( faster )?
If so use the REV switch.
Make sure the prop is spinning in the proper orientation.
