RCU Forums - View Single Post - Wild Hawk motor problem
Old 01-01-2010 | 04:55 PM
opjose's Avatar
opjose
Default RE: Wild Hawk motor problem
Just to clarfiy...
If you do this:
- Set everything back to the way it was when you recieved the plane.
- Turn on the transmitter.
- Hook up the plane and turn it on.
- Slowly move the throttle UP
Does the motor then begin to turn?
If NOT, AND you set the REV switch for the throttle, does the motor begin to turn when you do as above?
I'm trying to establish if even in the reverse throttle position your plane is giving you the full range of throttle response, and that the motor speeds up and slows down as it should.
Thanks.
